using shared variable data binding
I'm trying to show the progress of writing 9 different files simultaneously.  HostDownload.vi calls HostFileWrite.vi (a reentrant VI) 9 times in parallel.  I would like the the total number of loop iterations and current iteration, within HostFileWrite.vi, to be displayed for each file on a front panel indicator on HostDownload.vi (better yet, the top level VI).  I thought to use shared variable data binding, but that will only give me the current iteration.  How can I set the Scale.Range.Max property for each indicator to total number of loop iterations?  Could I make use of the Scale property for the shared variable?  If so, how?
(3,055 Views)
Hi Faustina,
I looked over your code and you might want to take a look at parrallel for loops. It would simplfy your code great.
You set the Scale.Range.Max correctly but did not call in a loop so it would continue to update. As for you shared variable question this is a perfect use case. I also recommend just sharing the value over shared variables.
Hope all this helps
Joe Daily
may the G be with you ....
(3,034 Views)
