values written to a table are not preserved
I am building a tool based on state machine approcah as shown below:
Basically, this tool get access to a hardware device via its DLL file and send read request based on a predefined parameter values (parameters list), the recieved values are displayed on a table (output table).
The process is repeated for ever until user stop it.
in the mean time a log file is created and the results are saved on Excel file as shown below
Problem: the problem is, the timestamp is not saved in the excel file and this is because the timestamp is populated for short time on Output Table as shown below.
In the below picture, you can see that output values are written and displayed on Output Table, but timestamp is displayed for short time (I can see this during Highlight Exceution mode) and when a new output value is written the previous timestamp will disappear!
I can not find the reason of such behaviour, I want the timestamps and output values to stay displayed on the Output Table.
any advise?
I attached the complete project for your reference but is wont work without the hardware.
Best Regards
Hakam
Note: I am using Labview 2016
Message 1 of 15
(4,159 Views)
Accepted by topic author hbs_80
Hi hbs,
RACE CONDITIONS ahead!
Learn to use shift registers and your problems are gone…
General recommendation: use less local variables and (much) more wire!
Message 2 of 15
(4,153 Views)
Are you using Replace Array Subset Function: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/replace-array-subset.html it simply replaces the previous value.
Edit: Ignore this message.
uday
Message 3 of 15
(4,146 Views)
Hello GerdW
Actually this is my first project in Labview.
I am using shift register for the state machine and also for passing setting parameters but I can not imagine how can I use shift register for my Output Table. Both timestamp and output value are written inside the same loop.
Message 4 of 15
(4,145 Views)
Message 5 of 15
(4,142 Views)
Edit to my previous post:
You can also resize the Replace Array Subset Function and pass multiple values at the same time instead of two times. https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/replace-array-subset.html
uday
Message 6 of 15
(4,115 Views)
Hi udka,
I can not figure out how to use shift register for my Output Table
Local variable seems working fine netween states, but inside state "Read cito" I am facing the problem. How can I use shift register inside the loop itself?
Message 7 of 15
(4,112 Views)
Disclaimer: Local and global variables are advanced LabVIEW concepts. They are inherently not part of the LabVIEW dataflow execution model. Block diagrams can become difficult to read when you use local and global variables, so you should use them carefully. Misusing local and global variables, such as using them instead of a connector pane or using them to access values in each frame of a sequence structure, can lead to unexpected behavior in VIs. Overusing local and global variables, such as using them to avoid long wires across the block diagram or using them instead of data flow, slows performance. Source: https://www.ni.com/docs/en-US/bundle/labview/page/using-local-and-global-variables-carefully.html
-Coming to your problem Read : https://learn.ni.com/learn/article/labview-tutorial and https://learn.ni.com to learn how to use local variable and Shift register.
-Did you follow by expanding the replace array instead of two times?
uday
Message 8 of 15
(4,104 Views)
You solved it!
resizing the Replace Array Subset Function solved the problem
The log file is somehow not correct, it should be easy to correct it
Thank you udka
Message 9 of 15
(4,103 Views)
Hi hbs,
you solved the race conditon (mentioned above) by deleting the parallel access to the very same local variables - but you should still use a shift register to hold your "output table" data!
What's the point of having a stop condition in your FOR loop, but not use it?
Message 10 of 15
(4,081 Views)
