valve sequencing
Ok, I put autostart on Write.VI (with starting button it activates), initialized state machine shift register (if it's ok, there shouldn't be red dot on shift register?), and put false statment in case "2" to stop channels(LED), but it still doesn't make a difference. Sorry to bother you but really don't know what is wrong (probably my lack of programming experience)...
Message 11 of 16
(1,269 Views)
You can try to build on this VI, maybe it will  help you.
Message 12 of 16
(1,254 Views)
Accepted by koli99
Message 13 of 16
(1,253 Views)
Thanks for all the help, really appreciate it!
I look at your VI and just added LED(its easier for me to understand dataflow) in step 2. In step 3 I gave false statment on same data, which should turn off LED? Still don't understand how to negate previus case?
Thanks again!
Jure
Message 14 of 16
(1,248 Views)
I have finally managed to do what I wanted. Thanks everyone for help, especially ion.rosca!
I'm attaching VI if anyone is interested. (On front panel you have to select timings: 2, 4, 4, 6, 8).
Bye,
Jure
Message 15 of 16
(1,229 Views)
You are welcome.
Kudos are welcome as well.
Kind regards,
Ion R.
Message 16 of 16
(1,217 Views)
