variable doesn%27t work
Hello & good morning,
I have several VIs which are loaded by 'call by reference'.
I want to interchange instrument handles (e.g. from PXI instruments) between them and try to use a variable (shared and now global, because shared doesn't let the VI load at all), but it only works when I step into or just put a probe in the called VI. That's not gona work on the target PC without labVIEW environment!!
regards,
Koen.
(3,308 Views)
Why not just have the instrument handles be inputs to the VIs?  Then you can wire directly into the connector pane, even with the Call By Reference.
(3,285 Views)
my intention was to "hide" the instrument handles in the layer I wrote for the DMM, MUX & VCCs (initialize, poll, measureR, measureV, enable, etc...)
It's thow peculiar that the "variables" only work when One steps into or puts a probe in the VI where the variables are written?
I solved it now by casting the different instrument handles (IVI class) to string, where string type is available in a proprietary c-dll for read/write (i/o storage write/read)
regards,
Koen.
(3,276 Views)
Sounds like a good place to use an Action Engine.  Then you don't care about the handle since it is just stored inside of the Action Engine.
(3,265 Views)
