variant data
I have  a variant data. See attachament. I tried using variant to data function to get each values inside the variant.
Is there any way to extract or get each values in a variant data type? How is it usually done?
Nghtcwrlr
(4,486 Views)
If you are using the value of the variant, you pretty need to know what the data type is.  There is a Variant to Data node that you can use.
(4,480 Views)
Not only did you post to the wrong board, you are cheating by posting a bmp file that you simply renamed. Please, you really don't think that a rename will actually change the file format do you?
(4,467 Views)
Sorry Dennis... my mistake. Smiley Tongue was in a hurry so didnt get time. Should I not post this question in LabVIEW thread? If wrong, where?
I tried Variant to data node. But it didnt work.
Nghtcwrlr
(4,420 Views)
Accepted by Nghtcrwlr
You need to wire a Datatype to the Variant to Data to determine the conversion. /Y
Qestit Systems
Certified-LabVIEW-Developer
(4,400 Views)
You originally posted this in the Breakpoint board.  I had the moderator move it to the LabVIEW board.
Use the context help (Ctrl+H to toggle it on/off).  You will notice if you put your cursor over the Variant to Data node that it explains that you have to supply a data type to convert to.  You can wire anything into the data type, such as an array of doubles.  If you don't supply a type, it defaults to a variant.
(4,395 Views)
