@Yamaeda wrote:
I'd say the Remove duplicates test is flawed, as the test is unlikely to actually remove something. If you set the text to use 2 or 3 decimals you'll get some duplicates to remove.
The number of formatted digits is actually the first thing I changed when I looked at the code yesterday. 😉
Of course the code should perform equally well even if there are no duplicates. 😄
