version compatibility
Hi All
I am kiran.
I am using LV7.1 FDS. Can i install the LV8.0 FDS in the same PC so that i  can work on  different versions whenever required?
Plz suggest
Thanks and Regards
Kiran
(3,153 Views)
Yes, you can easily have several versions installed on the same computer.
(3,149 Views)
HI
whether i have to install install it in two different drives or how?
Can i work on LV7.1 even after installing the LV8.0 in the same drive?
kiran
(3,145 Views)
Hi kiran,
you can install them on the same drive in the same folder - that's the standard setting for the installer routine.
The different LabView versions use their own subfolder in the "National Instruments" folder on your harddisc!
I'm using 5 versions right now, all installed to the same (main) folder.
Message Edited by GerdW on 09-13-2007 09:38 AM
(3,142 Views)
Just a reminder...
You can install different LabVIEW versions, but the VI's are not compatible!
You can load 7.1 VI's in 8, but once they are saved in 8, 7.1 cannot load
them. YOu'll have to save them to previous version.
You probably knew that already...
Wiebe.
(3,137 Views)
