vi Analyzer
I am using LabVIEW 2010 development suite, I am trying to use the VI Analyzer but when I get to the screen for test configurations no options are showing under the tests section. All the check boxes are missing. I have tried the "Reset all Test Configurations" button but it did not help.
Jim
(3,698 Views)
Can you include some screenshots of the problem you're seeing?
(3,689 Views)
Here is the screenshot, as you can see the check boxes for the test configuration is missing.
(3,680 Views)
Accepted by Jim_Glanz
Did you run the VI Analyzer Toolkit 2010 installer?  Without the toolkit installed, the tests won't show up in the UI.  You can verify this by looking in the following folder:
Program Files (x86)\National Instruments\LabVIEW 2010\project\_VI Analyzer\_tests
If this _tests folder is empty (or not present), then the toolkit is not installed.  Note also that the toolkit will only install to 32-bit LabVIEW.
(3,671 Views)
