.vi file download
Hello, is there a way to download the following .vi files from the internet:
- JYGetCurrent.vi
- JYMoveToWavelength.vi
- JYTurret.vi
- JYInitMono.vi
This is so I can run a photocurrent experiment using a spectrometer.
(1,307 Views)
Accepted by topic author solarfacility_user
Hello -User,
If the VI's mentioned belongs to Instrument Drivers/Library files related to the respective instrument which you wanted to control/measure, download the instrument drivers from the manufacturer website and and install the same to use for your development
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,300 Views)
Hi user,
You can download anything "from the internet" once you know its location… 🙂
- JYGetCurrent.vi
- JYTurret.vi
- JYInitMono.vi
Did you ask the manufacturer of that spectrometer for LabVIEW drivers? Those VIs might (!) be part of that.
Or you ask the person who created your VI about the missing subVIs…
(1,298 Views)
