vi for pH meter
   I'm new to lab view environment and i'm facing problems with developing a program for pH meter using RS 232.if anyone has the program for pH meter using RS 232 interface, i would appreciate if u could post me. Thank you in advance....
(2,718 Views)
I'm afraid it won't be quite so easy as that.
You need to know
1) What pH meter you're using
2) What the serial commands of the meter are
3) What kind of pH measurement you're doing
Of course, knowing how to do a proper pH measurement is a prerequisite, but we'll leave that for now.
There isn't a standardized RS-232 command set for all pH meters.  All manufacturers use different commands.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,709 Views)
