Christian_M wrote:
I'm wondering how this utility changing the names of his VIs should work, as the name of a VI is not programmatically changeable (VI Server) since it is saved once.
There's a method for this, which allows saving a copy or not saving it.
Here's one way of how this can be done (from MGI, LV 7.0). Note that it requires that you provide a prefix, so you need to change the dialog VI not to check for that if you want to start without a prefix.
___________________
Try to take over the world!
