vi not loadable with shared variable
vi not loadable with shared variable (even when SV in subVI).
(3,852 Views)
So?  If you have a question or problem with your code, we need to see the code in order to make (what we hope are) helpful suggestions.
Bob Schor
(3,845 Views)
Hello kdCMC,
I'm afraid you might have to give more context about your issue to get help with it.
1) What do you mean by "not loadable"? Can you not open the VI? Are you unable to see its block diagram?
2) What kind of shared variable is this? Is this a network shared variable?
3) Would you be willing to post the VI so that we can see if it opens on other systems?
4) What version of LabVIEW are you working with? Is it the same as the one used to create the shared variable?
Collin Draughon
support@ni.com
Collin D.
Software Product Manager
(3,841 Views)
Hello Collin,
1. not loadable -> VI call by reference
2. single process SV
3.
4. LV2014, yes
regards,
Koen.
In attachements: capture.png <- call by reference (if i remove the SV in the VI which is called, it loads)
I will post the VI with the SV later this day. I'm not near that PC right now.
(3,816 Views)
in attachement VI with SV
(3,809 Views)
when i'm using a global variable, it loads. Could save my neck here ( i hope).
(3,798 Views)
Hello.
Yes,
Global variables are always a good option.
"everything is achieveable through technology'
(3,794 Views)
