vi randomly opens
when i Open my VI,it loads up and also a sub VI (within) randomly opens as well.only started happening recently, but i cant see any reason this is happening? this happen for anyone else?
Message 1 of 8
(4,562 Views)
Accepted by dhanna
Check whether the Appearance is set to open when Loaded in the property of the VI which opening. You can check that in VI Properties>Apperance>Customize.
Message 2 of 8
(4,549 Views)
brilliant. never knew that existed. I dont know why it suddenly turned on like that though?
Message 3 of 8
(4,534 Views)
No other way it may get enabled. May be by mistake mostly.
Message 4 of 8
(4,529 Views)
I have recently been having an issue with an old setup that I dont have much experience with. (I am working on restoring a very old test procedure). And when I try to open random vi's labview seems to default to opening the same RELAYS.VI and will not open anything else. This seems to be very strange behavior and I am at a loss for ideas. Any suggestions?
Message 5 of 8
(4,268 Views)
@ghannah412 wrote:
Any suggestions?
Turn this setting off which P@Anand mentioned and resave it.
Message 6 of 8
(4,236 Views)
That setting is not an option with the LabVIEW version that is installed on this pc. And additionally its not 2 vis that are opening simoultaneously. Any time I try to open a vi the wrong vi opens and its not possible to get the correct one to open. Quite a bizzar and frustrating experience.
Message 7 of 8
(4,196 Views)
Can you open a new blank vi.
how are you opening the vi-  From File>>Open.. or from Windows explorer (assuming windows)
What version of LabVIEW is installed?  What version was RELAYS.vi written in?
Is this really source code or are you trying to open a file inside a 8.6 layout executable build output?
Message 8 of 8
(4,178 Views)
