vi randomly opens
when i Open my VI,it loads up and also a sub VI (within) randomly opens as well.only started happening recently, but i cant see any reason this is happening? this happen for anyone else?
Message 1 of 8
(4,908 Views)
Accepted by topic author dhanna
Check whether the Appearance is set to open when Loaded in the property of the VI which opening. You can check that in VI Properties>Apperance>Customize.
Message 2 of 8
(4,895 Views)
brilliant. never knew that existed. I dont know why it suddenly turned on like that though?
Message 3 of 8
(4,880 Views)
No other way it may get enabled. May be by mistake mostly.
Message 4 of 8
(4,875 Views)
I have recently been having an issue with an old setup that I dont have much experience with. (I am working on restoring a very old test procedure). And when I try to open random vi's labview seems to default to opening the same RELAYS.VI and will not open anything else. This seems to be very strange behavior and I am at a loss for ideas. Any suggestions?
Message 5 of 8
(4,614 Views)
@ghannah412 wrote:
Any suggestions?
Turn this setting off which P@Anand mentioned and resave it.
Message 6 of 8
(4,582 Views)
That setting is not an option with the LabVIEW version that is installed on this pc. And additionally its not 2 vis that are opening simoultaneously. Any time I try to open a vi the wrong vi opens and its not possible to get the correct one to open. Quite a bizzar and frustrating experience.
Message 7 of 8
(4,542 Views)
Can you open a new blank vi.
how are you opening the vi-  From File>>Open.. or from Windows explorer (assuming windows)
What version of LabVIEW is installed?  What version was RELAYS.vi written in?
Is this really source code or are you trying to open a file inside a 8.6 layout executable build output?
Message 8 of 8
(4,524 Views)
