vi server, multiple exe instances - example?
I have created a VI and made an exe.
I would like to run 10 instances of this exe.
I have tried opening another instance while one is allready running, but labview/windows does not seem to allow it....  😞
Reading the forum, it seems like I need to use VI server to do this?
Has anyone got an example on how I can go about to enable multiple instances of my exe (or vi)
Goose
(3,495 Views)
If your file is called Foo.exe, open Foo.ini and add the line allowmultipleinstances=true in the [Foo] section (create it if it does not exist). Then, each call to the exe should launch a new instance.
Note that you should be careful about using common resources between instances (e.g. files).
___________________
Try to take over the world!
(3,494 Views)
Wow, thanks, it works like a bomb!
(3,491 Views)
