How do you get an RTF stream to work ?
I'm trying to get a Richtext box as a screen logfile to work.
I've used RTF with EditstreamCallback in MSVC 6 & want to get the same thing working in labview. (I'm using 8.2 Professional)
I can't seem to find any relavent examples in the help or forums.
Has anyone done this before & is willing to reveal how ?
The Stream allows content to be added till you run out of ram & swap without loosing anything & keeping scroll back to the beginning & doing the memory management for you.
Text, fonts, colour, tab settings, images etc can be added to the RTF box.
It can be saved & printed.
I have tried & made a RTF control display from a saved rtf file, it doesn't track adding new content & has to be reloaded for each update made.
I have made 'rtf command text' be displayed direct but I have to do the buffering work & have to add onto the previous text line each time.
Both of these seem to me to use resources a lot.
Any help appreciated.
Chris
(3,470 Views)
hi there
have you tried the "RichTextBox" control from the ".NET and ActiveX" palette? Never deald with that, but maybe its useful.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,460 Views)
The two goes at making it work used that LV control.
You then have to register a callback for the stream to read in the new information when you want to add something.
That's the bit I can't get to work.......
Ta,
Chris
(3,455 Views)
Can you post what you've done so far?
(3,446 Views)
