vietnamese font error
hi guys,
I am a LabVIEW new learner from Vietnam.
From the forum I found out a way to set up how to use Vietnamese in LabVIEW. It works well with string control and string indicator, but when I try to use some function like the "on button dialog" I still get the font error like the picture below.
I also try to add "UseUnicode=TRUE" in LabVIEW.ini, but it does not help at all.
Any ideas for me?
Message 1 of 9
(2,835 Views)
Accepted by Justin_CN_Ruan
In addition to "UseUnicode=TRUE", the text has to be set to "Interpret as Unicode".  This is a text property that gets applied character-by-character (like font attributes); thus when you set that property, it only affects the characters specified that are selected.
Also, there is a property of string controls and constants called "Force Unicode Test"
When it is set to FALSE, as you type text, it tries to figure out if the text is ASCII or Unicode.
When it is set to TRUE, as you type text, it always assumes that it's Unicode.
Message 2 of 9
(2,804 Views)
Some LabVIEW calls, such as the one-button dialog and two-button dialog, are "system" calls rather than LabVIEW ones.  These system calls do not accept Unicode.
I had to add Unicode support to one of my applications to be used in an overseas factory and when I did so, I had to replace all calls to pop-ups like that (plus a few other functions) with custom-made ones that do support Unicode, and they do use the property that Paul notes in his post.
Unfortunately I can't share the custom popups I made as they are both company property and integrate with some other custom company code as well.  But replicating pop-ups isn't too difficult, hopefully.
Message 3 of 9
(2,777 Views)
That is very useful information. I wonder if that was the problem with my last failed Unicode attempt 🤔
Former Certified LabVIEW Developer (CLD)
Message 4 of 9
(2,769 Views)
Thank you, Paul. I will try with your suggestions
Message 5 of 9
(2,751 Views)
I found out that LabVIEW functions like a one-button function, they are using the font "Segoe UI". If there is a way to change the default font of the function, that would help a lot without building another function
Message 6 of 9
(2,692 Views)
You can set Application Font-key in labview.ini (and/or your applicaions .ini)
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(2,561 Views)
Thank you for your suggestion. I tried to look into the community for the help and I found this post: https://forums.ni.com/t5/LabVIEW/Text-Font-used-in-Executables/td-p/1594026
I tried to add some setup with a Vietnamese font, and it worked.
Here is the result, and I think it's not so bad at all.
In the picture, I wrote "đây là tiếng việt"
But when tried, it will affect the other non-unicode language like Chinese
Message 8 of 9
(2,479 Views)
@paul_a_cardinale wrote:
... thus when you set that property, it only affects the characters specified that are selected
yes!
you can try this manually by selecting via mouse
Message 9 of 9
(2,460 Views)
