visa compatibility
Hi, i want to install  labview 2014 32 bit but i want to ask that is their any other version of visa for this version because i have already installed  visa 16 for labview 2016 64 bit.Are there different version of visa for 32bit/64 bit labview versions?
Ransher
Message 1 of 8
(6,060 Views)
Accepted by ransher
Just perform another install for NI VISA 2016 after you install LabVIEW 2014 and the support should be installed.
Message 2 of 8
(6,039 Views)
Accepted by ransher
Ransher
According to this chart, your version of VISA should be fine for both, but after installing another version of LabVIEW, you have to install all the drivers again so they can "attach" themselves to the new version.  (In this case you won't really be installing the exact same driver.  It will be the 32-bit version of the driver.)
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(6,036 Views)
Thanks for reply Bill.i have one more question why labview 2014 32 bit not available for download ?Can i download in student version ?
Message 4 of 8
(5,988 Views)
@ransher wrote:
why labview 2014 32 bit not available for download?
Try here: Web-Based Installer LabVIEW Development System 2014 SP1
Message 5 of 8
(5,984 Views)
i tried it before also but it does not show any download option. i have attached screenshot
Message 6 of 8
(5,979 Views)
I wonder if you can register your student license with your account.  That might allow you to do the download.
Message 7 of 8
(5,974 Views)
yes @crossrulz i did before it exactly what you just said but found no way out to download labview 2014 32-bit development system.
please provide if possible any other way for downloading it,thanks.
Message 8 of 8
(5,972 Views)
