visa open and close with "for loops"
Hello everyone
In my program I used two "for loops" which include visa write and read for a RS32 port. it is not possible to close a devise with visa close as the out put is changed to 2D array!!! would you please help me with this error
Message 1 of 9
(3,851 Views)
Right-click on the output tunnels to turn off the autoindexing.  If using LabVIEW 2012, then it is "Last Value" for the tunnel type.
GCentral
Message 2 of 9
(3,848 Views)
Thanks for reply,
It works for "for loop" but what about "event structure loop" still is error for that.
Message 3 of 9
(3,843 Views)
Hi sam,
disable indexing of "VISA resource" wire output tunnels in every loop in every (event) case...
Btw.:
- It's no good idea to have events running for long/undetermined periods of time. Really!
- It's no good idea to hide (or even delete?) labels of controls/terminals...
- It's no good idea to start coding with a lot of local variables. They tend to lead to race conditions...
- It's a good idea to clean up a block diagram. It is easier to read then...
Message 4 of 9
(3,837 Views)
@sam009 wrote:
Thanks for reply,
Right-click on the output tunnel and uncheck "Use Default if Unwired".  You will now be forced to wire the VISA Resource through each case.
GCentral
Message 5 of 9
(3,818 Views)
Dear Gerdw
thanks for reply,
-I put 1000 ms for event stuctre time out if you mean that.
-the labels were hiden for better reading. anyway the progam with full lable is attached.
-just 3 local variables are used do you think it makes a problem.
and sorry I didn't understand what do you mean by disable indexing.
thanks
sam
Message 6 of 9
(3,813 Views)
I unchecked "Use Default if Unwired" and error is this:
"The type of the source is 1-D array of
VISA session of class.
The type of the sink is VISA session of class."
Message 7 of 9
(3,809 Views)
You need to do the same thing to the tunnel for the VISA wire on the innermost For Loop that you did for the For Loop that is a couple steps out.
As Crossrulz said in his post "Right-click on the output tunnels to turn off the autoindexing.  If using LabVIEW 2012, then it is "Last Value" for the tunnel type."
Message 8 of 9
(3,788 Views)
Thank both of you,
I did and problem solved. thanks
Message 9 of 9
(3,780 Views)
