I have tried to connect only one instrument, it still did not work. I found out from the producer that the instrument has a IEEE488 card on 16 bit, and the problem could be that this card is not compatible with the 488-2 functions.
I have tried to use GPIB functions (not VISA) but it gives an error (error code 0) each time I try to write and read. I have also tried I/O assistant, I programmed a sequence and I executed it step by step and this works (I can communicate to the instrument, I configured Tokens), but when I tried to use the configured I/O assistant it did not work, it blocked while executing it. I have also tried to save the I/O assistant as a vi, but it does not work since it makes reference to GPIB fuctions.
Is there a solution?
Thank you
Angela
