visa resource name function
HI Good day to everyone!
I am beginner at LabVIEW, and currently i am testing on one project.
Data from device will store in STS series server ( which has 16 com ports).
But I actually need to use 7 com ports from STS series server. I need to read those data from 7 com ports and save into a file.
Each com port has different function ( such as data reading or display).
My question is,
1) How VISA resource name function works for 7 com ports at the same time in one VI?
2) How can I choose different com ports to do different functions?
(2,698 Views)
Accepted by wintd
The VISA I/O resource control will show you all of the com ports you have available on your computer.
So you just need to make 7 copies of that control and set each one to a different com port and use that for each VISA write and read series of functions that you do.  (Have you looked in the Example Finder for serial port examples?)
(2,694 Views)
Hi Ravens,
Thanks for the reply and I will try look more into it.
(2,682 Views)
