visa
in the below attached image what is the meaning of icon which is in dropdown list beside com1 com5 & lpt1
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,452 Views)
     You mean "refresh"??Sorry I accedently pressed me too button.
Thanks as kudos only:)
(3,446 Views)
No above refresh & on the corner of COM1, COM2 & LPT1....... That green color icon is there. What is the meaning of that green color icon
--Ranjeet
(3,433 Views)
HI,
The symbol means that the VISA resource is still open - ie the COM port is still in use. You'll need to close the port before you can use it again.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,428 Views)
Accepted by Ranjeet_Singh
Yes...If the ports are idle then no such symbol can be seen.Just check it out.
(3,425 Views)
Thanks a lot guys............
--Ranjeet
(3,411 Views)
