visa
Good Morning,
My name hani mustika, I am a last years student in an Engineering School
I have a question, I'm making the wavelet system with the input signal is cardiac signal; and the output is normalized energy. I use a simulator of the different cardiac signal source, first using cardiac signals originating from outside labview (using Visa), then the second one uses the heart signal simulator derived from additional toolkit labview, I'm confused why the results differ? Are there any errors in the Visa?
Message 1 of 15
(5,893 Views)
I have to confess that I have no idea what you mean.  They're different because they come from different sources and have different data?
Bill
CLD
(Mid-Level minion.)
Message 2 of 15
(5,878 Views)
Accepted by haniadi
Your conversion of the VISA Read to an array is just silly. Obviously, a single point read is different than an entire waveform from the simulator.
Message 3 of 15
(5,871 Views)
different source and the same data, first source is ekg simulator ( from outside labView and use Visa to Connect between LabView and ekg simulator). Second source is Ekg simulator from inside labView  (Uses biomedical Toolkit).
i wil display 2 picture of source ekg
Message 4 of 15
(5,860 Views)
are you help me for this problem?
Message 5 of 15
(5,857 Views)
Do you have a solution for my problem?
Message 6 of 15
(5,847 Views)
I have no idea what that box is. You need to acquire a waveform before passing it to the wavelet function. You can acquire multiple points with a for loop.
You already marked my answer as the solution. Why do that and keep asking questions?
Message 7 of 15
(5,827 Views)
We also have no idea what is actually being returned by the external simulator. The only thing you show is conversion to a scalar.
Message 8 of 15
(5,818 Views)
I'm just totally confused.  It sure looks like two different sources to me?  Do you even know the output waveform is the same?
I'm thinking it could be a language barrier.  Maybe you can post better in your native language?
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(5,798 Views)
sory, i am new member, so i dont know about rules in this forum
Message 10 of 15
(5,743 Views)
