vision assistant screen coordinates
Hi there,
I am evaluating the vision assistant addtion to labview.  I have managed to use the applications features to identify two edges a want to track and control.  These edges are constantly moving and I need to know their location with respect to a known point on the screen say 0,0.  The idea will be to eventually keep the edge in centre screen by means of an external control system.  I can see that the straight edge function creates a couple of coordinates which I believe are screen coordinates.  It also mentions an angle of the line of 280deg but I am unshure what this is referenced from.
So far I have only been able to run the image analysis on still images in vision asssistant which I have grabbed from a live video feed.  How can I input the live feed (in the first instance a recording in avi format) and check that the processing is still sound at 30 frames per second for instance?  I then need to get this process into labview so I can analyses the coordinates (with respect to 0,0) as the edges move.
I tried to create a VI from Vision Assistant but I can't as I'm only evaluating it at the moment.  I notice all of the functions are available in Labview, is it possible to build it there directly and cut out Vision assistant.  Obviously if I can prove this is likely to work I will purchase the vision assistant licence which should make life easier.
Any help would be most appreciated,
Regards
(3,106 Views)
Post here for better response on vision related queries
And put a note in this thread that t has been shifted (IF at all you wish to do so)
(3,096 Views)
(3,087 Views)
