Meine Controls werden auf einem Client (WebServer) nicht akutalisiert.
I have visualisation software written with labview. The local application (created with Application builder) works fine. If i connect with a client (IE8, IE7 and Firefox), the web  page is shown, but the controls will not be updated (even if i change a tab!!). Do you have an idear?
biba0507
(3,240 Views)
Hi Biba,
just few questions. Have you correctly followed these steps:
How Can I Use Remote Front Panels With LabVIEW Executables?
http://digital.ni.com/public.nsf/allkb/7F95D43D3F50FCAC8625710E000068E1
Is the development enviroment completely shut down whe you run the executable?
Best regards
Andrea P.
Ni Germany
(3,208 Views)
Accepted by topic author biba0507
Hi Andrea,
thanks for the answer. I found the solution.
I had the problem, that I configured the main VI in the application as reentrant. In this case, it seems that the web server starts a new instance.
After disabling reentrancy, the problem was solved.
regards,
biba0507
(3,200 Views)
