Meine Controls werden auf einem Client (WebServer) nicht akutalisiert.
I have visualisation software written with labview. The local application (created with Application builder) works fine. If i connect with a client (IE8, IE7 and Firefox), the web  page is shown, but the controls will not be updated (even if i change a tab!!). Do you have an idear?
biba0507
(3,224 Views)
Hi Biba,
just few questions. Have you correctly followed these steps:
How Can I Use Remote Front Panels With LabVIEW Executables?
http://digital.ni.com/public.nsf/allkb/7F95D43D3F50FCAC8625710E000068E1
Is the development enviroment completely shut down whe you run the executable?
Best regards
Andrea P.
Ni Germany
(3,192 Views)
Accepted by biba0507
Hi Andrea,
thanks for the answer. I found the solution.
I had the problem, that I configured the main VI in the application as reentrant. In this case, it seems that the web server starts a new instance.
After disabling reentrancy, the problem was solved.
regards,
biba0507
(3,184 Views)
