Showing results forĀ
Search instead forĀ
Did you mean:Ā
vision
hi ,
can i use camera at the same time to grap the photo to analysis ?
and other question is that , can i use Ip cam with labview vision ?
i think i have asked too much question
but if anyone can help me ,
i will fully appretiated with that
Shing
(4,963 Views)
hey , i want to make some supplement.
is using two different camera to grab the image at the same same
i don't know how to solve this problem.
thank you
(4,959 Views)
Dear shingy,
It is possible to acquire images from multiple cameras simultaneously. I need to know a little more information before I can help your further:
Can you expand upon what you mean by lp camera? What type of camera is it (firewire, GigE, analog,...)? Do you have the manufacturer and model number?
What version of LabVIEW are you using?
Here is an example using the IMAQdx driver that should work for both GigE and Firewire cameras, assuming that your cameras are compatible. In acquiring from multiple cameras at the same time, you must be careful not to to exceed the maximum available bandwidth. This can be accomplished by setting the acquisition parameters and video modes for your cameras in MAX.
Please let me know some more details, and if you have questions about the example and above explanation, and I'll try to elaborate further.
Best Regards,
~Nate
(4,933 Views)
thank you Nate
your explanation is very clear and make me easy to understand.
but i have little bit confusion ,
i just only want to use two common camera
to grab the image at the same time  .
what is IMAQ dx ? where can i find it ?
thank for your help
Shing
(4,918 Views)
Dear Shing,
The driver that you will need to acquire images from your cameras is dependent on the type of cameras that you have. You will need
NI-IMAQdx if you have either Firewire or GigE cameras
NI-IMAQ
if you have either Analog, Digital, or CameraLink cameras
NI-IMAQ for USB if you have a USB camera (webcam)
Now this part can be a little confusing:
NI-IMAQdx is a licensed driver that you need to pay for. NI-IMAQ & NI-IMAQ for USB are both free. NI-IMAQ and NI-IMAQdx are bundled together with a couple other pieces of software in what is called the Vision Acquisition Software. NI-IMAQ for USB comes as a stand-alone driver.
Both the Vision Acquisition Software and the NI-IMAQ for USB are available for download on ni.com. If you need the NI-IMAQ driver, don't worry about the licensing prompts for NI-IMAQdx. NI-IMAQdx will revert to a 30-day trial, but you will be able to use NI-IMAQ beyond that.
Best Regards,
~Nate
(4,911 Views)
really really thanks your quick reply and full explanation , nate
i get your meaning , now i am using
NI-IMAQ for USB -USB camera (webcam)
so how can i grab the image using two USB camera at the same time ?
shing
(4,906 Views)
Dear Shing,
Unfortunately you will not be able to acquire from two USB cameras at once. It is a known limitation of this driver. See the driver page below for more details:
NI-IMAQ for USB Cameras
http://zone.ni.com/devzone/cda/epd/p/id/5030
Best Regards,
~Nate
(4,901 Views)
