voltage out from parallel port
Hi there,
I want to use the parallel port to run a relay.
I do not understand the example given by labview. I also read the forum but I did not see what I am looking for.
I am kindly asking if some one can write a small program ( I use labview 8.5) so I can give a 5v out say to pin #2.
Thank you in advance
(3,088 Views)
I am kindly asking if some one can write a small program ( I use labview 8.5so I can give a 5v out say to pin #2.
Please tell us more why you struggle, this is not good enough
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,073 Views)
The voltage out of a parallel port is not necessarily 5V. Modern motherboards usually only have 3.3V, if they even have a parallel port. Besides the voltage, the current is more crucial. What kind of relay are you trying to use? The parallel port is not a power supply, and it cannot source or sink a lot of current. It is not designed to power relays. It is designed to interface to logic chips. Your next question will probably be: how much current can I source or sink with the parallel port? The answer is that it depends on the motherboard. You will have to check your motherboard's specifications.
A far better solution is to use some sort of driver circuit or a DAQ device. Please perform a search on this forum, as this question comes up very often, and the answer is always the same.
(3,054 Views)
Guys ,
Thank you both. I actually solved the problem. It was easy I could not understand what value shout I send to the pins.
Now I know I need to work in the system with base 2.
Smerucurio I am aware of the information you gave but thanks. In order to run the relays I put in series with the pins a resistor of 5K
so the current never exceeds 1ma and I connect it in series with a transistor of gain 50 so I get enough current to run it.
(3,032 Views)
