vpim-windows.exe installation error
I'm downloading vipm-windows.exe from here: https://lumen.ni.com/nicif/us/evaltlktdigbus/content.xhtml
when I double-click vipm-windows.exe under Windows XP Pro, I get the following error, see .jpg below:
is there a work around?  I want to see the I2C example from IPNet
(4,708 Views)
Probably not enough rights? Try to run it as Administrator.
(4,703 Views)
vipm is VI Package Manager, a tool distributed by JKI (http://jki.net/vipm). You may also want to look at their support forum for it here: http://forums.jki.net/forum/5-vi-package-manager-vipm/
(4,701 Views)
really, I linked to the vipm download from "NI Free add ons".
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209123
Page below makes it seem like an NI product, but I now realise it's from JKI
http://sine.ni.com/np/app/culdesac/p/ap/global/lang/en/pg/1/sn/n21:28/docid/tut-11903/
I'll check out this laptop I'm using and the jki help forums, many thanks
(4,697 Views)
downloading vpim-windows.exe from location below solved the problem
https://lumen.ni.com/nicif/us/evaltlktvipm/content.xhtml
(4,695 Views)
I give up, can't get VIPM to install under Windows XP, initially got extraction error when running the .exe file.  Then I got through the installation sequence but now when I try to start VIPM I get the windows error "This application failed to start because the application configuration is incorrect.  Reinstalling the application may fix this problem".  Re-installing does not work.  Been through lots of posts on the VIPM help forum, looks like it's riddled with bugs.  My settings.ini file at C:\Documents and Settings\All Users\Application Data\JKI\VIPM contains only "[General] IsFirstLaunch = "TRUE"", so I figure VIPM never actually runs otherwise this file would contain details about my LabVIEW software.
Is there a way to access the NI supplied code without installing VIPM ?
(4,674 Views)
Accepted by topic author bmann2000
found it
https://decibel.ni.com/content/docs/DOC-1151
(4,671 Views)
