warning: connection to the target (cRIO)has been lost
Hi uma,
you still run and close the FPGA VI more than once…
Message 11 of 15
(1,297 Views)
hi GerdW,
i want to call different channels from  different modules(9215,9215) to indicate different values ,then how can i use single FPGA vi reference for running and closing FPGA??
in first loop iam getting the load value from 9219 module,
second loop pressure value from 9215,shall i use the same FPGA reference??
can you give some example  please ??
Message 12 of 15
(1,293 Views)
i tried to open and run once,i did it.but iam not able to close using single FPGA reference.
in below screen shot is what i have tried.
Message 13 of 15
(1,291 Views)
Hi uma,
first run the FPGA vi, then branch the wire to the different loops!
Message 14 of 15
(1,281 Views)
Dear GerdW,
understood.
i will follow hereafter.Thank u so much for your response.
Message 15 of 15
(1,279 Views)
