wav file encryption using TEA
Hi kulsman,
you still attach a LV2013 version of your VI. You should use "Save for previous" in the file menu...
Message 11 of 22
(2,480 Views)
Hello GerdW,
It seems like labview saved the file into a new folder.
Message 12 of 22
(2,477 Views)
Bump anyone
Message 13 of 22
(2,462 Views)
Hi kulsman,
read as U8 array:
Message 14 of 22
(2,443 Views)
I have implement your suggestion, but I am getting this wierd error.
Error 116 occurred at Read from Binary File in reading_in_data.vi
Possible reason(s):
LabVIEW:  Unflatten or byte stream read operation failed due to corrupt, unexpected, or truncated data.
Please view the changed file.
Message 15 of 22
(2,436 Views)
Accepted by kulsman
Hi kulsman,
I appologize, that's my fault.
You have to provide a scalar U8 as datatype for ReadBinaryFile:
(Reading the context help really proves helpful...)
Message 16 of 22
(2,427 Views)
Thank you so much. I am finally able to read in the wav file.
Message 17 of 22
(2,406 Views)
 Hi Kulsman,
I am also working on a project trying to do encryption on a waveform data. Were you able to decrypt and recreate the wav file after encryption? If so, how?
Warm Regards,
Matt
Message 18 of 22
(2,362 Views)
Hello GerdW,
I am also trying to do encryption, but instead I am trying to do TEA on a waveform data. Is there a way to pass a double into TEA and encrypt it? Because if I convert the array data of the waveform (which is type double) into U32, all of the values become 0 since the waveform values are never greater than 1. Attached is a picture of what I am trying to do. Thanks for your help.
Warm Regards,
Matt
Message 19 of 22
(2,354 Views)
Hello GerdW,
Warm Regards,
Matt
Message 20 of 22
(2,354 Views)
