waveform chart to excel
He's using LabVIEW 8.0.  I'm not sure this will work with that.
Message 11 of 21
(2,158 Views)
i am using a wavfor chart not an XY graph will it still work?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 12 of 21
(2,157 Views)
i have it in version 7.0 if you need it..
i am not sure either..
but it work  for me on xygraph
look like it should work
try it out. i did. it worked
Message Edited by krispiekream on 11-14-2008 02:18 PM
Krispiekream
Message 13 of 21
(2,155 Views)
ok thanks I will be here so just comment when you get back from lunch
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 14 of 21
(2,150 Views)
Excel Plot is a seperate VI am i currect?
if it is where do i get it?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 15 of 21
(2,136 Views)
i attached it in the first post of the picture.
you might have to delete some worksheets.
i had multiple worksheets with different graphs..
you can just use one...
Krispiekream
Message 16 of 21
(2,134 Views)
this might be a dumb question but can you attach the VI that you posted the picture as?
because i have only been using labview for about 7 months and dont know some of those VI'S
Thank You,
Harold Timmis
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 17 of 21
(2,131 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=273490#M273490
or here
Krispiekream
Message 18 of 21
(2,126 Views)
if you could can you send it in the 7.0 format because i am using labview 8.0
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 19 of 21
(2,119 Views)
Krispiekream
Message 20 of 21
(2,100 Views)
