waveform display
hi everyone,
This is my first post in Labview community. I hope someone will reply. I am a beginner to the Labview. I am working on a strain guage type load cell device and its interface to PC by Labview. I want to show the waveforms of the load cell response. How can I do that? And I am going to apply different load on the load cell. How can I show the waveforms on the screen? Pls reply urgently...
(2,704 Views)
Assuming you are using an NI DAQ board, you wire up the results from the DAQmx Read or the DAQ Assistant to a waveform graph indicator.
I suggest you make use of the DAQmx tutorial at https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page... and the resources for learning LabVIEW at https://learn.ni.com/learn/article/labview-tutorial.
(2,694 Views)
