waveform graph 3D
I'm new in LabView, I want to show waveform graph in 3D (like below) and how to change the caractertics of it?
Thank you very much
Yours sincerly
Rira
(3,008 Views)
To do a 3D waveform graph, I would use a buffer (2d array). When you acquire (1D), you add it at the end of your array, and delete the 1rst line. Then you plot your 2D array in a 3D XY graph => this will do a 3D waveform graph...
best regards,
V-F
(2,992 Views)
