waveform graph not showing increments properly
Can anybody please check my code and tell me why my waveform graph is not showing as follows
It just shows as follows
(3,743 Views)
Your x-scale marker values are set to .1 .2 .3 .4 .....  But your X max is only .001, while on you other picture is 0.4
(3,728 Views)
Appreciate your help. Can you please underline where I am wrong because I still did not get it.
Thank you again.
(3,697 Views)
Accepted by bufferlab
Look at this part of the code.
oscilf
(3,692 Views)
Thank you. I understand the mistake now and it is working.
(3,671 Views)
I am trying to use this scope to acquire data from Scanning Tunneling Microscope. We are using NI PXI-6120 simultaneous-sampling, multifunction data acquisition device. It is in PXI-1042 chasis. Unfortunately, STM machine stopped working. I cannot check whether this scope works or not. Is there any way I can check it works or not. I mean like can I send signal from anywhere into the physical channel. Or can I connect virtual function generator signal to the physical channel or any other way.
Can anyone please check my code or me. I will really appreciate it.
Thank you
(3,670 Views)
Hey bufferlab, could you create a new forum post for this question since it's on a different topic from your initial question? This will help others who have similar questions easily search for your post. Make sure to put key words in your post title as well. Thanks for helping out the community!
Francine P.
Applications Engineering
(3,655 Views)
