waveform graph problem
Hi pazhani,
      I have attached you a vi that i have made and also the model vi to you, compare it yourself, you will find what i was exactly wanted to create.
Message 91 of 95
(2,234 Views)
Hi Gregoryj,
             Actually i need a solution to select which channel i want to display in a xy graph from channel 1 to channel 16 in X-axis or Y-axis that user can select but in the vi i have send you i can plot it only for first two graphs but i need to plot it for all the 16 graphs and also at the same time whenever i select scale name also should change that's why i use a property node but unfortunately it was also works only for first two graphs so i need a solution to clear this issue.
Thank you in advance,
Dinesh
Message 92 of 95
(2,232 Views)
Hi Dinesh,
please don't create several threads for the very same topic. Keep things in one place!
Message 93 of 95
(2,224 Views)
hi butcher,
    i have tried to run your vi but  when i was trying to save the data in a spreadsheet file, the time array it was not working properly it was itself repeating the same repeatedly,i mean the time starts at 0th sec and at 10 th sec again it starts from 0th sec, i don't now why it was happening here?
Message 94 of 95
(2,192 Views)
Hi butcher,
       I'm Dinesh and i need to know how can i run the channel selection window without stopping the main vi from the example vi you've send to me.
Thank you,
Dinesh
Message 95 of 95
(2,174 Views)
