waveform graph
Hi
I have got following type of data
Array of Time      Array of data1    Array of Data2
19:41:40                     2                     3
19:41:41                      2                     2
19:41:42                       2                   2
Can anybody tell me which property node can change axis of waveform graph. And where I have to connect my time and data1,data2. Data1 &2  are to be plotted against x-axis(array of time).
(4,063 Views)
Hi mimran,
first of all it would help to woirk with numbers instead of strings... See attachment!
(4,052 Views)
Or if you want to use a regular graph, convert the times to numbers, subtract time 0 from time 1. That is the dt of a waveform data type. Use the Build Waveform function.
(4,050 Views)
Hi GerdW
Your VI is very helpful. AT the moment, xy graph is only handling data1. Is XY graph capable of drawing two different graphs like data1 & data2 together.
(4,038 Views)
Accepted by topic author mimran
Hi mimran,
please switch on the context help of the graph to see how to draw more than one plot in the graph... Or look for some examples coming with LabVIEW!
(4,027 Views)
I have managed to draw multiplots on xy graph but time on my x-axis has disappeared. My range of data is around 56000. Have a look on my graph and data.
(3,996 Views)
