web server connection broken
I have the same problem.
My VI has a lot a events arround 100 and some property nodes, the size of the file is around 5mb because it has images.
I read about modifying the labview .ini file to make bigger the queue of messages (it says that by default it has 500) increasing to 1000 it could help. Is this possible?
I can't make less events because the user needs to click on them in order to obtain some information, is there a way to solve this?
Regards
Message 11 of 12
(1,008 Views)
HI
Same issue Iam facing now. Did you got the solution for web server connection broken error. Can you share the solution it helps me a lot.
Thanks!
Message 12 of 12
(755 Views)
