web service example
I'm trying to create a simple rich client interface for a labview web service VI but am having trouble creating the interface.  In the Web Services webcast (http://zone.ni.com/wv/app/doc/p/id/wv-810) a simple Adobe Flex interface is created.  Is it possible to get the source code for that interface or something similar?
-Derek
(3,917 Views)
Hi Derek,
Elijah also made a really nice Dev Zone article to go along with that webcast.  It has all of the steps needed to get the thin-client application up a running, including the source code.  All of the code is inside the .zip file at the bottom.
I have attached the Adobe Flex user interface source code below if that's all you wanted.
Hope this helps
Justin Parker
Product Support Engineer
(3,889 Views)
Thanks Justin for your help.  Maybe I'm missing something, but how do I access the attached file?
(3,879 Views)
Justin forgot to attached the file.
But the files you want, are in the zip file at the location he wrote
(3,868 Views)
