web services executeable installer
I am Using lv8.6 and made web application
when i made an installer for it it works on my own machine(after installing) and not work on any other system
what are the things i have missed OR any other issue any of u know please inform me
regards
mazhar
(2,790 Views)
Mazhar-
            It depends on what your executable is doing. Does it communicate with hardware? Did you include the drivers for that hardware? Did you add all the dependant files that are needed? Here is a good tutorial on building executable applications http://zone.ni.com/devzone/cda/tut/p/id/3303. I would start here and think about an additional installer if you need it. Hope this helps!!
(2,760 Views)
Mazhar-
             Did you find the tutorial I linked helpful? If you are still having problems then let us know and we can pick it up. Also, if you find a post that answers your question exactly then you can make it the "answer" and it will help future posters out. This is a question poster privelage so I was just letting you know in case you didn't 🙂 Cheers!!
(2,740 Views)
