webcam comparison
check this
Message 11 of 17
(2,430 Views)
Sorry for the long reply because I had internet technical problems but this didnt help. How can we compare 2 images???
Message 12 of 17
(2,381 Views)
Have you tried the IMAQ Compare.vi?  It's in the Operators pallet and there's an example available.
Message 13 of 17
(2,374 Views)
Ok and how can i change the imaq capture output to read boolean. If images are similar then true and if different then false.
Message 14 of 17
(2,369 Views)
That is what my attached vi is doing. You have to further add some processing. If I were you i will add a auto threshold and find if there are any particles. If there are any particles then it means there are difference in the images.
Message 15 of 17
(2,352 Views)
ok i got it but the buffer element is not found in labview 8.6 so do anyone know an alternat element
Message 16 of 17
(2,332 Views)
Do you mean imaq create?
Message 17 of 17
(2,298 Views)
