webservice at windows start
Hi guys
Is it possible to make a labview webservice launchable at windows start? how?
thanks for your reply
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(3,319 Views)
sorry I mean "Launchable at windows start" = "can be started in the same time as windows start"
(3,293 Views)
Do you want to start the service "NI system (or Application) Web server" before logging into user account?
Or do you want to start your executable (with web interface) after WIndows starts? https://support.microsoft.com/en-us/help/4026268/windows-10-change-startup-apps
Note on the second option, it seems they want to allow registered apps only.
step #2  "Right-click the app, select More, and then select Open file location. This opens the location where the shortcut to the app is saved. If there isn’t an option for Open file location, it means the app can’t run at startup." I would try to create shortcut for the file manually and specify it on the next step.
(3,275 Views)
Are you sure the OP isn't looking to launch something simply using the Task Manager?
(3,270 Views)
