weighted slope of a 3x3 matrix
Ok, I have a somewhat unusual maths requirement (well unusual to me anyway).
Say I have a 3x3 matrix, each with a value (0...255).  Assuming this represents the surface of a physical object (and I know that the center box is not zero), I want to get the surface vector in order to be able to work with the "slope" of this surface.  Clear?
Example
0 0 0
2 2 2
2 2 2  Must give a normal of zero,
2 0 0
2 2 0
2 2 2 Should give normal of -1.
0 0 2
0 2 2
2 2 2 should give a normal of 1
And so on.  The hope is that through the weighting of the boxes (a larger number carries more weight in the calculation) I can simulate more than just 8 directions.
Also, the output (plus/minus and so on) is flexible, I simply must be able to correlate this to a surface normal (always pointing up).
I've tried placing artificial points on an XY plane in each of the 8 directions with the distance in the given direction defined by the respective number within the matrix.  This is half-satisfactory as it seems to bear SOME resemblance to a logical answer, but it's not quite there.
Can anyone help me?
Perhaps it's better if I ask if anyone can understand me?
Looking forward to any help
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,966 Views)
OK, I think maybe just thinking about might have jolted some dark distant thoughts from way back....
If I simply get the mid-point of all the points I have artificially created and use this and 0,0 as two ends of a line, the slope of this line should be representative.... (?)
I'll try to get an example up.
Sometimes my lack of numerical prowess is really depressing 😞
Shane.
(2,962 Views)
OK, just to finish up a silly thread.
I have it sorted, as long as the matrix isn't symmetrical, whereby I get a NaN.....
This is my current code (much of the code is for comparison purposes only).
If only I could think properly, I wouldn't be polluting the forum with this stuff,
Shane.
(2,959 Views)
Shane,
This sounds like fun. I have a math handbook which has lots of stuff on 3D analytic geometry. To translate their nomenclature to LV code, I need to understand your "surface." Does the 3x3 matrix represent the Z-axis values at 0+/-1 on X and Y? If you can explicitly define the surface in 3D, I can generate the normal fairly easily (I think)>
Lynn
(2,956 Views)
