what TCP IP ports are used by CRIO
NI,
what ports or range of ports are used for cRIO by NI for:
LabVIEW development system
NI MAX
RAD tool
NI Network Browser
NI distributed system manager
We are setting up VPN connections and firewall settings and understanding these items is very important to us.
Thanks in advance.
Stu
(4,998 Views)
Accepted by srm@viewpointusa.com
There are some posts about this already on the forums - you might find them useful:
http://forums.ni.com/t5/Real-Time-Measurement-and/Exactly-what-ports-are-used-to-communicate-with-a-...
https://forums.ni.com/t5/Real-Time-Measurement-and/Cannot-access-cRIO-behind-NAT-firewall-with-MAX/t...
I believe that both UDP (for discovery) and TCP (for communications) are used by MAX.
You could also consider using a network sniffer tool like Wireshark to see what connections are being used.
(blog)
(4,986 Views)
thanks.  i don't know why those threads did not come up with my search.
Stu
(4,975 Views)
