what are system requirements for labview runtime engine 2011
I'm looking for the system requirement for LabVIEW Run Time Engine (2011 version ideally). The only information that I can find just states what operating systems it supports. I am wanting to check the specification for a target (a Touch Panel Computer - probably running Windows XP Embedded), to allow this to run. Specifically the amount of non-volatile system storage needed - as we will need to specify a CompactFlash card. Clearly the application exe will take some space as will XPe, but I'm wanting to know about the needs of RTE.
Andy
Consultant Control Engineer
www-isc-ltd.com
(3,567 Views)
Accepted by AndyClegg
Not sure about complact flash..  I can't remember seeing it in the relase notes, but follow the link below for the manual:
It should support the touch screen (I can't remember if you still need an extra plugin for that... I'll check).
https://www.ni.com/pdf/manuals/371778g.pdf
look at page 2, middle column
or shown below are the basic requirements:
(3,559 Views)
Have a look at this thread where they discuss touch panels:
 And this link which describes how to run LabVIEW on Windows XP Embedded.
 Yuo will notice that it mentions:  "Using LabVIEW with Windows XP Embedded is unsupported. The exceptions are, Windows XP Embedded is supported for use with the LabVIEW Touch Panel Module."
From what I read LabVIEW Touch Panel Module is extra and requires licenses.
(3,547 Views)
Ray - many thanks for the speedy answer. Perfect. We have used the LV TPC Module to create executables for other third party TPCs. It was just the disk space requirement I was unsure about.
www-isc-ltd.com
(3,537 Views)
Perfect, so you should be good to go 😉
(3,534 Views)
Typically, you would mark the most helpful post as solution, not your own thank you post. You can change it.
(3,531 Views)
