04-19-2006 12:06 PM
04-21-2006
08:16 AM
- last edited on
04-13-2024
05:14 PM
by
Content Cleaner
Hi sgundappa,
If you are able to communicate to your PLC and publish it via an OPC Server you would be able to use LabVIEW and the LabVIEW DSC Module as an OPC Client to communicate with it in LabVIEW. Also there is and Industrial Automation OPC Servers CD that can be purchased separately for use with LabVIEW and the DSC Module that will provide drivers for PLCs. I did not see your PLC listed but it might be worth a look at the link below.
LabVIEW DSC Module
https://www.ni.com/en-us/shop/product/labview-datalogging-and-supervisory-control-module.html
Hope this helps,
Steven B.
