what would cause a subvi to show its FP even when it is set not to show (default setting)?
@crossrulz wrote:
Then it is your calling VI.  If you right-click on your subVI call, there is a subVI node setup.  Make sure the "Show front panel when called" is unchecked.
I thought we excluded that possbility in post #6 above. Still worth double-checking....
Message 11 of 13
(599 Views)
Accepted by topic author billko
Hi, guys:
I found the issue.  In short, the VI's front panel was being programattically displayed elsewhere in the code.  Duh.
Sorry about that!
Bill
Bill
CLD
(Mid-Level minion.)
Message 12 of 13
(588 Views)
Kudos for everyone that responded.  🙂
Bill
CLD
(Mid-Level minion.)
Message 13 of 13
(583 Views)
