where can i obtain the Labview's source code (block diagram) for Triax 320 Spectrometer Software?
I have the software however some of the block diagrams are blocked by password. I am trying to modify the functions for my own needs. This software is developed by Jobin Yvon Spex.
(3,811 Views)
One way is to contact the developer of the VIs if he is willing to give you the password.
Another way is a brute force attack. Open a reference to the VI use the "Invoke Node" "Set lock state". Call it in a while loop until error out will have no error. For each call use a new password which you can generate.
I have tried this with a one character password to verify that this will work, but I have no VI generating all possible strings.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,811 Views)
Just as a notice:
There is always another way - in making your own software for a given device. In case of Triax, programming is not a complicated task, and, I must admit, the manufacturer's proper style of LV drivers program structure for TRIAX is not at all a good example of LV-programming (I've tried myself to rebuild all that can be rebuilded regarding documentation available).
(3,811 Views)
thanks for the comments.
Is it possible to send me your self build LV for TRIAX?
(3,811 Views)
Ok, I've worked for some time with TRIAX 180 (If I remember well). It must not differ much by command interface/programming side with a model you mention about. But the software I've done is a part of a bigger project and it's not so easy to cut the drivers out of there. So send me a mail at philippov_AT_celia.u-bordeaux.fr with a bit more information about what you need (controlling TRIAX itself? CCD? or something other?)and I'll see If I can help you.
(3,811 Views)
