where do I find the TRUE or FALSE boolean value?
I'm doing a program that displays the operation of global variable. I'm suppose to put a TRUE or FALSE boolean value and I can't find it. Please help.
(2,417 Views)
You can't find an indicator for the front panel or you can't find a Boolean constant to put on your diagram? You've got Boolean palettes for both front panel and diagram. Everything you need should be on one of the palettes. If that's not it, could you explain your problem in greater detail?
(2,417 Views)
