where is the DAQmx function at the labview
I am first time using labview as my school project using NI usb6008, i already install the DAQmx that contain inside the instrument, but when i enter my labview program, i coundn't find all the DAQmx function that require, may i know how to add the function inside??
Message 1 of 9
(3,432 Views)
The DAQmx functions should appear under Measurement I/O in the Functions Palette (LabVIEW menu >> View >> Functions Palette or right click on an empty space of a diagram). See attached screenshot from the functions palette of LV8.2.1.
If not, I guess that you didn't install the LabVIEW support with the driver. Please check if there is a DAQmx directory on your harddrive. It's default location is :
C:\Program Files\National Instruments\LabVIEW X.X\vi.lib\DAQmx
(X.X --> your LabVIEW version)
If not, reinstall the driver and check this option in the DAQmx settings.
Message 2 of 9
(3,412 Views)
ya...i cant see any daqmx directory when i choose go n see as the instruction u follow, so which cd is the driver support? the NI-DAQmx cd contain inside usb 6008 or the labview cd under the development system and application buldier, sorry i am 1st time touching labview, my question a bit silly
Message 3 of 9
(3,407 Views)
NI-DAQmx CD. Put it in your CD drive. Launch the installation and then check the LabVIEW X.X option in the DAQmx settings. That's all !
Message 4 of 9
(3,402 Views)
but when i insert the cd and install unser the NI-DAQmx/VI Logger already and sucessfully install i cant see any DAQmx icon, any setting require? able teach me step by step?, i actually cant understand what is the meaning to get labview x.x option in the DAQmx setting
Message Edited by 567888 on 05-04-2007 10:43 AM
Message 5 of 9
(3,401 Views)
Hi 567888-
Which version of LabVIEW do you have installed?  Assuming it is a relatively new version (current version is 8.2.1), you may need to download a newer version of NI-DAQmx than the version that shipped with the hardware.  The current version of NI-DAQmx is here.  It provides support for LabVIEW 8.2.x, 8.0.x, and 7.1.x.
Hopefully this helps-
Tom W
Message 6 of 9
(3,387 Views)
i using the driver 7.5 but using labview 8.0 is that the problem causing me cant see the function??
Message 7 of 9
(3,382 Views)
Hi 567888-
Yes- the NI-DAQmx 7.5 installer does not include support for LabVIEW 8.0.  You will need to use NI-DAQmx 8.0 (or later)- the link I posted above is for NI-DAQmx 8.5.
Thanks-
Tom W
Message 8 of 9
(3,372 Views)
ok..i try to do it...thanks a lot
Message 9 of 9
(3,368 Views)
